Please please help me with my radiator fan!!
(In Topic #164215)
Georgie's off the road boo
I rang GSF and they confirmed the one they'd send was correct for my car. I then rang VW, who quoted me a different part no. to the one on my dead fan…so I rang GSF back and they don't do a replacement part for that number…..ggrrrrrr!!!!Can anyone shed any light on what the heck's going on under my bonnet?! I have all the part numbers listed below…thank you so much for any help you can give me to clear the mud!!
- Current fan (AEG)- 191959455AA
- VW quoted fan (AEG) - 191959465A
- 2 female socket connector - 191972525A
1. change the rad fan loom and switch for a 2 speed one to match your fan
2. get the 3 pin plug that fits and splice the fast speed to your old 2 speed wiring leaving the slow speed off
3. get a 1 speed fan from a 16v or a low spec mk1/2 (edit: 1 speed not 2, oops)
the tricky thign is there are several fan plugs around so you'll need to make sure the one you have matches up to the fan
Last edit: by rubjonny
Please help can't I just buy a 3 prob switch for my rad and fan ?
oops, choice 3 should be single speed fan
Dubpirate said
Hi the golf I have just purchased with a new loom in is backwards to this my loom has a 3 socketed plug and my rad has a 2 pin switch in
we could have just done a swap!!
My 2 pin fan has died and I need a shiny new one, but they are all 3 pin.
I'm not to technically minded so I could really benefit from a walk through. Been on the phone to VW Heritage who advised to get hold of:
1H0906233 (One on eBay currently)
357972742/A
357972742/B
I am desperate to get a working fan as being stuck in traffic for more than 5 minutes results in having to turn around or switch engine off. Any help would be massively appreciated…
Pictures would be even better : )
1990 - Cabriolet GTI 1.8 (DX)
as i say there are a few different plugs around so get the fan 1st then get the loom to match it
edit: 1h0xxx is MK3 golf part number, and afaik mk3 fans dont fit mk1/2 properly
rubjonny said
if it was me, mk2 golf 3 pin fan, loom and thermoswitch, job done
Thank you rubjonny.
I bought a second hand fan from eBay for £20 (3 pin) // Cut my current connector and fitted 2 x new spade plugs and wired to the 2 outer pins. For the time being this is doing the trick.
Don't suppose you could point me in the right direction for the parts you mentioned? As you know mate I'm pants at this! - Will this be a job for an auto electrician / Garage?
Mine is off to the garage Monday to have new pump, cambelt, clutch bulkhead plate and new clutch cable fitted
with the 3 pin thermoswitch its a standard part used across the VW range from early 80s to early 90s so easily available, AVS do them:
AVS Car Parts - [The VW - Audi - Seat - Skoda Parts Specialist]
Decided to park this until the new year now. The fitting of the pump and other parts cost a little more than is hoped.
Need to put some money to one side for;
New battery
New alternator
New starter motor
Then will come back to this as my temporary solution seems to be holding out for now.
