Exhaust manifold remove and stainless steel header install
(In Topic #221140)
My 1,6 1983 golf has had this sound as if the original cast manifold had a crack somewhere, quite loud. unable to find any other holes in the exhaust I decided to just bin the old system completely and go for a stainless system all the way. The cars quite low and the middle damper catches on sometimes so I’ll be going with a setup without this as well. Will it be less noisy than before? We’ll see but at least it will be as its supposed to be and I can install the extra damper if necessary.
My worries were mainly on removal of the 35+ years old original manifold, and unable to find so much information on the subject but with some pointers from Brianos posts (cheers mate ) I thought I’d give it a go.
Now the main concern doing this is avoiding to break any of the studs coming from the head of the engine. If this happens you’ll be forced to try and out-bore a broken hard steel stud from a much sorter aluminium head, which means if your drill slips… its just not a fun task to do while under your car anyway, which is why I prepared myself for removing the engine from the car if it should happen. Also I will not recommend doing this job at home on the ground at all. You’ll need the car on a lift to be able to remove and fit the parts from underneath, and to reach the manifold etc.
Anyway why dont I tell you what I did rather than ranting on about what not to do.
Car on the lift, lets crack on
Start by removing the air filter box for better access to the 4 upper bolts on the manifold
The 4 upper bolts can be taken from above you can see my wrench in the picture
Problem here is that the space between the intake and exhaust manifolds are so narrow that I could only fit 1/4” 12mm sockets in there, and the bolts were on there really good, so trouble can be expected here..
This started happening
Because this old stubborn bolt just wouldnt let go..
Oh and remember to remove the bracket thats Holding the intake and exhaust manifolds together. Its 3 bolts to remove.
Impact air gun with wobble extension was used, ended up breaking the wobble extension..
Heating by starting the engine didnt work, nor did heating the bolt with a torch..
Managed to get a 3/8” modified socket in there and which helped in the end but..
I ended up rounding one of the bolts… great!
I was unable to get a small cutting tool in there and cut the bolt, there simply wasnt enough space.
So I had to sacrifice my 3/8” 12mm socket, making a cut in it so that I could put in on the bolt and with the welding machine make a weld so that the socket was on there solid.
It actually worked after a couple attempts
After I got it turned some more I was able to put more welding spots in.
Finally the thing was of
3 studs came out but I had a full set of new stainless studs and bolts
In with the new studs and the new gasket after a proper clean
Put the new manifold on there and bolt it on with the new bolts
From there its just fitting the new exhaust or make a joint to the old one. I’m going 2,5” all the way out.
I’m really happy with the end result, its hearable of course but its a much better sound than before
Hope this might help someone in the future
I have a short pneumatic butterfly impact, it actually fits the gap between the firewall and the area nicely. A couple of flips zipz that is after soaking the nuts in PB-Blaster for a week, before every day made short work.
Went back with Stainless Steel Studly's and the copper nuts….
Looks and probably sounds nice, and you gained about 15 SOP HP.
Yeah sure I used copper grease on the studs prior to fitting the new one, always apply on new stainless steel items to prevent them making a bond.
Also BTW I can only recommend the use of a gearbox lifter when dissembling the manifold from the downpipe-thing thats sitting on the manifold with 2 solid C-clamps, its easier to get those of if you’re able to lift the downpipe slightly to release tension from the clamps..
nice with the compact butterfly impact, I couldnt fit neither air or 18v impact in there directly without wobble.
Cheers for top advise as always!
Few pics attached. Any help or ideas appreciated.
Possibly the drive shaft but not sure as when I fitted mine I had the engine out so the manifold went in before the engine and gearbox.
Last edit: by Shubbs
Did the same thing on my dial down pipe on my next Cabriolet, I used left over sheet aluminum. Some folks over here use that exhaust heat shield tape, but being the Cost effective person that I am, I used what I had laying about, and if my header cracked I wanted to see it.
an OBTW on all 3 of my Cabbies with the OEM exhaust manifold they all cracked, I suspect that it was from poor design, and broken mounts.
My old Toilet Bowl on my diesel never cracked in the 20 years of ownership.
My cars a daily drive so don't know if that makes much difference?
Also wrapped my steering rack boot with a plumbs soldering mat as it's right next to it on left hand drive cars.
Picture on page 1 in the link to my build thread.
https://vwgolfmk1.org.uk/forum/index.php?page=topicview&id=projects%2Fyour-mk1-golfs_2%2Fmy-daily-drive-1988-gti
And totally love the build thread. Was thinking about publishing mine when she's done.
Shubbs said
Thanks for the info mark1gls, yeah I'm planning on using mine not necessarily as a daily but using it pretty often. So it's interesting yours has been ok for last 7 years as a daily. Maybe the wrap isn't so bad after all. I read that it's can overheat the headers and causes early breakdown in the material which oxidizes over time anyway. Thanks for the real world use scenario let's me gauge kinda what works and doesn't. Appreciate that! Think the wrap option is easier to install that getting/making heat shields. But yeah briano also mentioned the steering rack needs some sort of heat shield so I will certainly do that also!
Hj,
Did you decide to wrap this after all? Currently doing the same thing and was going to wrap it, just seeing what you decided to do in the end.
