Doing timing. Two marks on cam sprocket. Pictures.
(In Topic #182910)
Which one of the markings do I use?
I used the marking on the outside of the sprocket (away from center of engine) to set the timing, but the car will not fire.
Then I see that the sprocket also has a marking on the inside. These two markings do are on completely different place on the sprocket.
So, what is the correct marking?
Utside:
Inside:
Last edit: by dubmission
Info here.
View topic: Setting up timing, - pics - The Mk1 Golf Owners Club
Thanx a bunch!!! Finally after much work I have the car running. What a great feeling Shot a little video of it running to prove itmark1gls said
Its the marking on the inside (nearest the engine) The mark should be level with the top of the head not the rocker cover.
Info here.
https://www.youtube.com/watch?v=oVyEoqJJcmE
