Dellorto twin 40s
(In Topic #136330)
Dellorto twin 40s
Hi, i have recently purchased my first carb'd MK1 1.8 clipper cabby, after more than my fair share of MK1 Cab GTI's i now feel like a novice again as i am only use to fuel injection. Anyway after spending out £325 for a solid 89 clipper cab with 89k on the clock i have just bought a set of Dellorto twin 40s, usually i hear alot about webers etc and i am wondering if these Dellortos are going to be any good and also can anyone give me a heads up and what else i will need to fit these on my car as i only have the carbs.
Thanks in advance for any information
Lots…
Inlet manifold, throttle linkage, fuel lines, fuel pressure regulator, fuel pump…plus sundry parts.
The popular inlet manifold needs porting as they are too small internally. Then, the manifold needs matching to to head.
Im a BIIIIIIG carb fan, but I wouldn't fit them as a first choice mod.
www.jmrclubsport.com
Cheap carbs can mean cheap for a reason. .so beware.
Lots of parts available so no probs to re furb them unless there's something wrong internally. .any pics?
Make a note of all the jet numbers, including in particular the choke size.
If you like a challenge you now have one!
You'll also need misab plates for mounting the carbs to the manifold, an inline filter, fuel hose, and a heat shield between the manifolds.
Also..the clutch cable will foul the second trumpet in from the left..looking from the front. . from memory a scirroco or diesel cable clears better as it runs tighter to the bulkhead.
I am running twin dellortos on mine. I had a few problems like jetting and a cheap throttle linkage. once this was sorted i had them set up on a rolling road.
I must admit a twin carbed engine sound awesome and its interesting to drive.
You might also want to consider making an airbox because the filters play havoc with the clutch cable and they sit above the manifold.
so a small air box with a cold air feed should help performance.
I will attach some pics:
Rebuilding Again…
Good call…
Contact developments (Dellorto UK) stock all the parts needed and are very helpfull to deal with.
I run a single 40 dellorto, bought a pair and then sold them on again as it looked a whole world of pain getting it all sorted.
The heat sheild is a definate for the conversion as is an electric fuel pump, the mechanical one on the clipper will not deliver the fuel needed.
The air box could be tricky if you are planning on retaining the rain tray in the engine bay!
Projekt Frustration :
White 1991 Clipper. Lowered over polished zender rims, Single 40 dellorto on lynx manifold, kent cam, full stainless 'zorst / manifold, powerflex bushed and braced. Not the fastest car, but sounds super nice!
Still going after 12 years… never said it was a quick fix! Time is not my friend.
Are there any guides on the forum for installing and setting up these carbs?
I'm looking at doing this on an ABF with twin 45 Dellortos
Daily - T6 Transporter
Other - Mk1 GTI 20vT
Similar rules apply to an ABF as it does in this thread.
Be careful what you buy used as there's a lot of useless junk out there. Carb jetting is fairly straightforward to get them running nice before a rolling road set up.
Inlet manifolds are important…a poor flowing one will cap back any carb gains. A good throttle linkage is a must.
Carb conversations can often be slated when poor/warn carbs are used on a bad inlet manifold with a worn linkage and incorrect settings. Get the right carbs on a good manifold jetted correctly with a nice linkage and carbs work great.
Get yourself a book on it and have a good read.
https://www.ebay.co.uk/p/How-to-Build-Power-Tune-Weber-Dellorto-D-9781845849597/6020831876?iid=352578011095&chn=ps
Is the one I used.
Cheaper than buying the wrong thing and making costly mistakes. I think there may be a PDF out there too
https://www.mazdabg.com/ftp-uploads/Mazda/RX7/info/carb_book.pdf
JMRacing got any suggestions for a good linkage?
I have the 'black framed on the top of the carbs' style on my Derby and the return spring is too hard. Makes driving it in traffic a nightmare
Ian
Is the one I used.
Ian
Eurocarb do a couple of good ones, including the newer version with a cast frame and multi adjustment…its around 90 quid from memory. Worth a call to them, always honest and very helpful with any of my fuel system parts in general and the best source for Dellorto bits.
Some of the metal frame linkages are ok when new but can wear quickly.
