cutting out
Re-Seat that is remove and place back in EVERY Fuse in your Fuse Box.
Re-Seat every Relay….
Why? because you are cleaning the connections.
Here is a Fuse holder that I failed to clean in the 10 years of Ownership, well now that it has been replaced (the socket) and I installed a 30 amp Breaker, I shouldn't see that issue….. On a side note, I replaced the same fuse on my other car, and installed a breaker there as well….
Remove and Replace the Connections on the Coil as well.
Gremlins, weren't a AMC issue, they attack with a cunning eye to intermittent operation.
If you have a Carb'ed car and funny things happening under load, then you usually have an electrical issue.
You can Relay your Headlights, and Radiator Fan,,,,,
You can Relay your Starter as well (heat soak).
Cabby-info.com has all the CIS grounds and there is a link in my DIY's for Digifant…..(with Pictures).
I just helped a fellow, and it was the Coil connections being dirty that caused his intermittent stumble.
the main fusebox earth goes to the 4 way white spade block hanging off the end of the fat brown from the battery in your headlight loom. it'll have a few other earths on there, basically if its quite thick and has a black or brown spade housing then it should go to the white spade block. out the back of the block is another thick brown that needs to go to the earth claw above the fusebox.
include all of these plus the spades on your claws in your unplug and replug mission
Thanks again both for your detailed help, I will continue to work through your suggestions
Lemon Yellow Tin Top Restoration
http://vwgolfmk1.org.uk/forum/index.php?page=topicview&id=your-mk1-golfs_2%2Flemon-yellow-tin-top&kfs79=30
6v is low at your coil, if you have the resistance wire intact you should be getting about 9v when running, a bit more with with the engine cranking, and the coil should be a 9v, not a 12v.
1. Every fuse replaced with new ones
2. Coil connections replaced
3. side lights cause no drop, headlights cause more of a drop than the fan
4. Connections at earth claw re-seated
5. Nothing on the alt to remove, only a small plastic block with wire connection
6. Coil is 9v when the engine isn't running, its the wire to the coil which are 12v
7. Cleaned up the alt to starter and starter to battery ends
Fault remains, still getting a voltage drop
This is if you are still running with the ballast wire, if it's been by-passed and a 12V coil fitted it won't be so.
Whether the low voltage is your problem I don't know, I've got an old bike with two 12V coils, with electronic ignition fitted they're in series and only get 6V each, it runs okay.
Last edit: by cedar
when cranking you should see around 12v becasue there is a wire from the coil to the starter, this is there to boost the volts while its cranking
