1.8 8v carb engine on twin carbs
Is this right??
Phoenix said
ok swap the head for a GTi 8v head so you have the valves and the cam and job done,
use bike carbs rather than twin carbs for less hassle…..a lot less hassle, more reliable don't go out of balence anywhere near as much as twin carbs do.
Please check out my thread in the big block section is your advice to swap the head for a gti 8v head a straight forward swap?
Cheers Simon
It's ten years since i went out of my my mind - I'd never go back.
Mk1 1993 Cabriolet
Audi A4 SE Avant
Audi TT Roadster 225 Quatro
Mk1 1993 Cabriolet
Audi A4 SE Avant
Here goes:
My Cabrio is running a single DHLA dellorto 40 on a lynx M50 inlet manifold with facet pump and low pressure fuel reg.
It fits in the space (with 45mm spun alloy ram pipes), where as twincarbs would be hitting the rain tray/bulkhead with any sort of filter
It' is a bit rough to start as i'm not running a choke, but fine when you know how to cope with it.
On top of this i'm fitting a kent GSH2 cam at present so it should go a bit.
Cost is about ?250 all in, but sourcing the bits is hard, ebay can be your best mate!
Projekt Frustration :
White 1991 Clipper. Lowered over polished zender rims, Single 40 dellorto on lynx manifold, kent cam, full stainless 'zorst / manifold, powerflex bushed and braced. Not the fastest car, but sounds super nice!
Still going after 12 years… never said it was a quick fix! Time is not my friend.
Where are you
Cheers Simon
Mk1 1993 Cabriolet
Audi A4 SE Avant
Mk1 1993 Cabriolet
Audi A4 SE Avant
I dunno if I have any pics, I'll have a look.
Your more than welcome to have a look once it's back on the car, like most of the ancillary components it's sat in a box as I have the engine in bits!
PM me if you want.
What are you doing to your engine?
Cheers Simon.
Mk1 1993 Cabriolet
Audi A4 SE Avant
Mk1 1993 Cabriolet
Audi A4 SE Avant
I have stripped the horrid plastic off the looms and am in the process of re routing the looms.
I've got rid of the old rad + fan set up to be replaced with top fill rad and slimline fan to be mounted in front of the rad so you won't see it.
Then I'll be powder coating a few bits and replacing rusty nuts and bolts with new stainless steel ones and moving on to the rusty mess that was the wishbones and anti roll bar.
I also want to swop my rims for next year and maybe sort the rear beam out.
The job list is huge.
I'm also trying to source some new outer window seals/scrapers
