Replacement exhaust manifold DX
(In Topic #242616)
Last edit: by Bradcab
Bug back in the day. 2 were cracked so bad that I couldn't pass emmissions.
I opted on my Digis to go the G60 and 4-2-1 dual piped manifold, and a dual down pipe, First one was pricey, but the return in SOTP feel as 200 hp boost.
I made a Dual Down for my second one that worked well.
I bought a RACELAND header assembly to replace it but never got around to it.
The Forward silencer on the system isn't a silencer it is
a Pneumatic Hammer arrester (resonator) it stops the hammering effect of the exhausts. but doesn't interfere with the flow as when intact it is a sealed pipe that is surrounded by a Sealed Metal jacket. I never took them off as I liked quiet.
The Catalytic pervertor was a round or flat object of disdain that was before the Shifter box and right after the Down pipe 90 bend before heading to the rear.
So you had a manifold, down pipe, Catalytic convertor, resonator, then Silencer.
If you go with a header or a dual down affair, do not forget to include a flex connection between the down pipe and the back run. It stops the headers from Cracking after a bit from torque shift and the pipe from rattling against the chassis with engine flex.
I did once find a Stainless Toilet bowl flange listed, can't remember where, but it was almost as much as the Stainless Raceland that I bought.
