Noisy gearbox
So whilst I've got my Campaign on the road and historic road tax, running it is a good feeling after 8 years in bits - some jobs to do yet but annoyingly the gearbox is noisy.
When the clutch is depressed it goes quiet so defo gearbox whine.
Could it be the release bearing ? I've replaced it but may have got it wrong ??🤷🏼‍♂️ that would be the easy solution to replace….
If not think I'll have get a recon unit and get it fitted.
It's certainly fought me every step this Golf
MK1 Golf GTi Campaign:Alpine White, Vauxhall Omega MV6, Alpina B10 3.3 Touring, Dolomite Sprint, MG ZT V6, Volvo T5 R estate  6C2B5B6F-1CA5-44CA-A93C-6B7F5206CD7F.jpeg
Please respond here.
4 or 5 speed?
Make of Trannny Tj AUG
TJ was my Automatic.  :)
Have you changed the Gear LUBE. If you have a 5speed the 5th gear is splash driven, so if the fluid level is low, you can burn out the 5th gear.
It's 5 speed manual.
It's also leaking gearbox fluid out of speedo cable location" despite new gasket and fixing bolt being tight ? 🤷🏼‍♂️
