Elec window motors
(In Topic #221396)
Cheers Gaz
http://www.vwgolfmk2.co.uk/forum/viewtopic.php?f=68&t=47872
In my case it was 'sticky' bushes inside the motor, might be your issue also. If so a cheap and easy fix.
Failing that check out the politecnica80.com website… 54021 corresponds to one of their VW Cabrio window kits.
https://www.politecnica80.com/en/electric-window-lifters-products/optional/
On the drive
Myvalver 89 GTi Grey mk2 16v
The ones you have look aftermarket so will probably have gone bust or bought by someone else.. but similar way all kits work, so its a case of new stuff of ebay, and then add the parts that come, maybe need to adjust cut the connection only, and connect chocolate box style
On the drive
https://www.ebay.de/itm/NEU-Fensterheber-Nachrustsatz-elektrisch-vorne-fur-VW-Golf-1-Cabrio-Fensterheber/264316199212?hash=item3d8a79212c:g:bAIAAOSwO-Zc1GRE
Has the code 5054021 which I'm guessing is the full set up as the Politecnica site sequentially gives the individual window mechanism as 4854021 for the left and the right as 4954021.
https://www.politecnica80.com/Media/assets/3989/54021.pdf
The manufacturing date, according to the box sticker of the one above is mid 2017 so perhaps they still provide kits for the Cabrio, the company still exists and seems to be a major producer.
If you search eBay.co.uk using either 'Politecnica' or 'Opzional' it throws up a few bits at more sensible prices though none are directly Cabrio related… perhaps the motors are universal regardless of the part numbers or what vehicles the mechanisms are intended for, might be worth checking the images?
https://www.ebay.co.uk/itm/Opzional-4942071SCM-Renault-Laguna-2-01-01-Right-Front-Door-Power-Window-Kit/123729028892?hash=item1cced3271c:g:WNoAAOSw3WZZyB0N
Some of the UK hits are for Eurocarparts, they seem to stock the latest Opzional versions (inc. Cabrio?). If one was near you they might even open a box to let you compare motors.
Thanks again Gaz
