wiring in 1978 series 1 9a 16v
(In Topic #110914)
i am good with the mechanics side of things, iv done most welding, i can put the engine in my self, however electrics is a nightmare! if the car has no wiring how am i suppose to no where what connects??? can someone help if you no what im talking about
cheeeers
This is quite difficult i imagine, but could be done with patience, and also i have read of people swapping from the early fuse board to the later type with cartridge fues.
Or alternatively, you could stump up the cash and get a custom harness made up? Probs cost a canny bit that tho!
This is about all i can think think of at the mo. Hope it helps!
Good luck!
'78 Golf LS 20vt
‘08 Mk5 Edition 30 DSG
79-85 said
hi i'm sure tsr used to do a engine loom that pluged in, i've still got a diagram some where let me fish it out, and i'll post a pic.
Their engine loom connected dizzy, ignition ECU, TCI, a temp sensor and a couple of earth and power connections, it didn't do anything to do with the fuel pump, fuel pump relay, ISV or its module (or AAV and TTS) or WUR. For these, you could start from a GTI loom and make length corrections as needed. Also you'll have oil temperature sender to wire in.
What loom does your car have at present? Rev counter?
yes that sounds about right.
unmol said
ooo okay… my car was a i.i carb so has no rev counter aswell, this loom was ripped out b4 i got the car, but i can source a mk1 gti loom ov flea-bay proberly
There's 2 variations - what kind of fusebox do you have at the moment? Or are you not bothered about converting the wiring throughout the car (and adapting where needs be)?
unmol said
elo paul, i got the car without fuse box/wiring, so im going to have to use the gti loom with bits of 16v loom i guess?
Yeah but there's many variations of Mk1 GTI loom (at least 5, probably more). I'd be tempted to get the dash sorted first.
