Where to start?
(In Topic #90643)
Where to start?
I'm looking to start at the sills and work my way back to both rear arches, corners then rear panel. Before doing any welding I want to strip out the rear axle and fuel tank etc. However, what I'm unsure of is;
1. Where best to support the car to get axle out and then leave up in the air?
2. Once I've jacked it up, with the doors off, is the shell likely to distort when I do the sills? (Want to know the doors will fit when I put them back on! :wink: )
3. Yes, I am about to start my resto at long last!! :cheer:
Any advice appreciated
Personally I'd use a peice of wood and axle stands either under the original jacking points right near the back panel or just in front of the rear axle
are you doing inner and outer sills? mine was fine doing the outer only
no idea what you could do to prevent any possible distortion though :dontknow:
Look forward to seeing loads of restoration progress pictures :y:
Good Luck!
Secretary
Replace the sills first
You may find the corrosion so bad when you chop these off you may want to look for a better shell ? It has happened ! :wink:
Damn shame - would be cracking to have one and I'm sure a lot easier to work on the car.
actually it all sounds like alot of hard work!!!
