Wesley's 2.0l 9a 16v project using kr and isv
(In Topic #131951)
After having my 83 mk1 for 5 years now i have decided
to make a few changes,
1st is replacing the 1.8 8v DX Engine
for a 16v 2.0l 9a using kr injection and isv (if i can)
The car
Got this at a great price and it included the loom ecu & gearbox,
i will use the gearbox, loom, injection system, cams, air flow metre and maybe the head
and a 2.0l 9a from a corrado
also got a scirocco inlet manifold 42mm.
pipe from inlet manifold to airbox
and 16v scirocco injector hose's
This is a picture of the original 1.8 8v DX Engine
i'll be able to use the airbox from this engine and leave it in the same place,
just take off the dx mitering head and bolt on the kr one,
this is the reason i'm using the scirocco inlet manifold, to keep everything
much the same as original
This will probably be going back in
just want to re wrap the loom
Got some bits ordered aswell
Mainly gaskets
and the steel coolant pipe thats mounted on the engine
also
need to get 100mm drive shafts (i know i can change the flanges over from the 8v box to the 16v box
but if i can get 100mm shafts handy then all the better)
to suit the 16v box that i have.
i also want to use the isv.
i've tried everywhere including germany for a scirocco 16v kr loom
as it would connect straight into the mk1 fuse box
but cant seem to find one
apparently the kr was very rare in germany to as they
mainly had a pl engine which had knock sensors, lambda sensor and catalytic converter etc
is there a loom that can be got somewhere that has been changed already?
i see this loom on ebay but the chap selling it doesn seem to know much about what
the loom will cater for http://cgi.ebay.co.uk/VW-MK1-GOLF-CONVERSION-LOOM-FIT-MK2-3-4-16V-ENGINE-/330538945500?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item4cf5a80bdc
do tsr still sell this loom?
and does anyone know if it will do all
of what i need?
but i've found a tsr loom here for sale near home at €50
so happy days, probably be a week before i have it
1st took of some of the auxiliary's
and got it ready for a wash
Before
And after
Done a bit more stripping
16v exhaust manifold from http://dubpower.co.uk/
very happy with this
Fits perfect
And this rocker cover
it should look good when theres a few more matching bits with it
Decided to do the Power steering conversion that ronan done on Vagdrivers, had a good chat with him at limerick show last year about this
and seen as the engines out nows as good a time as any
http://vagdrivers.net/forums/index.php?showtopic=20511&st=0&start=0
took the rack out
and got a glanza rack
Put the kr cams in
and went about cleaning this dirty rocker cover
Anyone any tips on cleaning this and inlet manifold?
Gaskets plugs and water pipe arrived
need to order engine mounts now
MY BUILD THREAD
I'll go have a look at your build thread,
Did you use the mk1 oil cooler or the 16v 9a one?
i want to use the 9a one but just want to see what other people are using
