Underbody coating
(In Topic #72504)
Guest user
Underbody coating
The plan is to take the whole shell back to bare metal and get rid of every trace of rust, was thinking of doing the underside in a high content zinc paint then appplying the orignal vw rubery underseal, anyone done something simular? opinions on this please, its a car i plan to keep forever
There was a recent post about underseal etc. Opinion seemed to be from a few to try out the following;
http://www.rust.co.uk/
A little pricey but good stuff!
Guest user
I think i would prefer the rubber coating which they used from the factory on the basis that it would probably withstand stone chips etc much better, seems pretty tough stuff and with a good zinc paint under it i would imagine it would last a long time, the current stuff is all still on there even after nearly 25 years, what i realy want is someone who has done the same say 5 or ten years ago and there opinion on it
storm81, I think Rich (crazyquiff) is probably someone you should have a chat to.
He has done a few bare metal shell resto's (including the current Campaign he is working on). I think like you he used a high zinc based etch primer and then undersealed with some of the flexible, overpaintable sealant similar to the stuff used on the car originally.
Rich - you back from your hols yet?
Cheers,
Chris
Cheers,
Chris
Ive just finished the restoration of my shell and last summer I stripped every bit of under seal from the floor pan/inner turrets etc and treated it with epoxy mastic - this stuff is by far the best and it is rock'ard.
Give it two coats by either brush or spray. I brushed it on as I wanted a good thickness on it - I then had it sprayed the same colour as the panels and it came out really neat! Well pleased and no more rust! It will only be a dry day car anyhow but I still wanted the headache of rust delat with - BTW testament to VW as the only rust on the floor pan was at the rear of wheel well where the back panel meets it - the muck seems to gather there and do its worst!
I took the sealer off with a wire wheel on the hand grinder - dead messy but easy.
Control functions:
