Project JD
(In Topic #141088)
Project JD
hi all i've just bought a my first mk1 golf tin top gti i got it from JOE90K here are some photo's
what do you think
what do you think
update time got her to her new home for now ?
then found some more rust!!
and a hole in the floor
started to strip it out
thats it for today
thats it for today
Looks like you've got your work cut out for you there, keep the updates coming and good luck.
Nice Motor nearly as much rust as mine lol nothing that cant be fixed though im sure. Good luck
That is slot of work mate!
i started on a set of wheels before i got the car to see how good my spraying is
then i started on a S1 dash which needed alot of work
still got a lot to do on it i'm thinking of covering it in carbon fibre
todays update
took out the brake system and gear box linkage
then the rear windows found some rust around the seals it looks like surface rust so not that bad i think?
does anyone know how to remove the tailgate/do i need a special tool for it??
update still striping her down
the tailgate is out now
now thinking can i save the tailgate from the bin
another day at the office
got the rear axle off then started to cut out the fuel filler repair panel looks ok will is how good it is once i've welded it in
was thinking should i repair rear tub where it meets the fuel filler panel ??
then started cutting out the rear left hand arch and matching it up to the repair panel
then started striping out the sound deafening got half way through it and ran out of juice
thats it for today
thats it for today
hi all need some advise on what engine to put in her? thinking a 1.8T,1.4tsi g60 or find an 1.8 k injet an put her back to how she was. when i got she had no guts LOL
THE STORY SO FAR
repairs to both doors and wing
also the removed the tailgate lock and plated it
butleraw said
You're making good progress there. Did you repair the tub behind the fuel filler in the end?
haven't started on the car as yet hoping for better weather LOL
started the fuel filler repair an rear arch inner repair
got my new roof started prepping it
Good luck with this build Marlon i shall watch this with interest mate.
just a little update started building my rear disc conversion using polo 6n2 parts its looking good
not finish yet just waiting on brake lines and disc an pads
also started work on the tailgate striping it down to bare metal then a bit of filler over the part were i removed the lock and welded it up
should be spraying Epoxy 421 on it soon
just a quick up date go a garage now so the car is out of the rain LOL
started removing the under seal to find more rust i'll let the photo's do the talking
started to weld in some new metal but then ran out of MIG gas and ran out of petrol of the Generator long ting LOL
Last edit: by marlonjd
Design Manager
Awesome! Good to see my brothers old car is getting sorted! Looks good so far mate, some of your pics aren't working properly on Photobucket, would be interested to see how far you have got! Keep going though, will be worth it when its done!
2018 Up! GTi 1.0 TSI
2015 Mk7 Golf R 2.0 TSI 4motion DSG
2011 Caddy Maxi Kombi 1.6 TDi
1982 Mk1 Golf GTi 3 Door 1.8t - Build Thread
just sorted photos LOL
