Project F
(In Topic #107310)
Project F
I hail from SA Durban and these are some pics of the mk1 Fox im building for a track/road car .. it doesnt have MOT/COR yet so i am busy stripping it and doing what is still legal so i can pass it then comes the cage race seats etc
Please comment as i need as much help as i can get 8)
Keep the pics coming!
Dibbler
Thanks for the comments guys
keep thinking how cool it will be when im done
Powerflex Black - Golf Mk1-REAR KIT
PB120VW
Price (INC vat): ?108.47 Quantity:
Product description:
Your question is "will they be too harsh". Answer: do you like cornering fast? - in our opinion essential for high performance applications. "Black" suspension bush kits. We supply Powerflex kits complete for front or rear suspension applications. Kits include all bushes required for front or rear application including anti-roll bar mounts and drop links. Damper bushes are not included in the kits due to the fact you may have new dampers or be considering buying them. In addition non-suspension bushes are not included - e.g engine or exhaust mounts. The improvement in response from one of these kits is superb, especially on cars >3yrs old. If you prefer all bushes are available individually - please email with your requirement.
The Black shore 95 bushes are around 35-45% stiffer than standard and are ideal for motorsport use. Unlike a Nylon bush enough compliance remains to make them safe and prevent damage to other suspension parts. Powerflex Black Bush kits bring: More secure on limit handling Minimum geometry change under extreme loads. Economy through longer life.
Powerflex Black Bushes made to order hence delivery time 3-7 days
Now I need some help with the settings on the machine and Gas PLEASE .. because it was a balls up ..
Holes anyone ..
So i found the grinder and the spanners and operated those abit ..
removed the struts ..steering rack and grinded down some factory welds from things i had removed
inside
Outside .
So i need to learn to weld .. i dunno how the F to do it with this kinda machine .. It burnt the sharp point i kept making which i was told to do .. and it kinda welded the rod onto the point making it a ball .. and burnt holes in the car
Try on some scrap steel with setting down low and just keep increasing until you get good penetration without burning holes.
Take a look here - Welding - The DIY Guide
I know it's only for MIG but may be helpful and show you what a perfect weld should look like! :wink:
anyway I have since removed the back axcel and petrol tank and today I cleaned up and repainted the wheel arch inners
Working on getting the stuff needed for Rear disc conversion and wondering about upgrading the fronts as well, dont want to change too much once I assemble if I can help it , hunting a FI petrol tank aswell
and planning on running a Beetle master cylinder … like this setup …
These are my pictures below from today ..
and one of these
