overhaul off front end
(In Topic #86189)
so engine out, windscreen out, dash out, wiring looms out, suspension half stripped i ran out off time
just couple off questions
1. the scuttle panel (if thats wat u call it) is rotten so i removed will this affect the strenght off the car if so will a strut brace sort it?
2. the tin worm of the bit with the heater blower on is bad how do you think is best to repair i was going to clean all rot off and put a fresh panel over the top off the lot and there for making it smooth or you think it would be best to patch wat i got
got more pics i took on sunday will upload tonight as dont have time now
hello!
hello!
I have also been told that the engine temps get a bit higher but not sure if thats true or not.
Using a strut brace would help to put some strength back into the car.
Lots of people go for smooth scuttles though and i like the look of them.
Good luck
paul
83 MK1 GTI G60 85 MK2 GTI 20VT 2004 SEAT ALTEA 2.0 TDI SPORT
paul_h said
only problem with removing the scuttle is you loose you chassis number.unless you weld it back in somewhere else on the car.
Good luck
paul
i have seen others with 'smooth' scuttles but always wondered what they do about the heater matrix as the loose the hile for it. another thing i'm worried about is the rain cover over the heater matrix is now unfitable so i will get water straight onto heater fan. i did ponder welding up grill on the bonnet or getting a 'scoop' like on dougelove's cab but never ever seen one up for sale
i have pm'd crazy quiff and he is willing to chop up a good shell he's got for parts for me so all i need is to draw on a pic for the cut lines and he's happy to do it
hello!
still need the cup off the suspension but all hammerited up and waiting for it and some new bearings will post some more pics up later
good old crazy has sorted us out with a panel off a scrapper to put in the place off the main rust spots just got to pay him for it now. its coming mate trust me
hello!
1. Can't fit rain tray - if you don't, then rainwater will get onto the heater blower motor and wiper motor. If you remove the grille from the bonnet, then you will have little/no ventilation into the car. And the air that does get in will be warm from the engine bay.
2. It creates a box section, adding strength. Removing it will reduce this, which can't really be put back by a strut brace.
3. As before, removal of chassis number - fail MoT?
Show cars tend to be garaged all the time and many are trailored to-from events. Also, many don't have heaters, or windscreen wipers!
i know ur prob not gna do 130, but may affect the downforce, as alot of air goes through the grill, imagine sticking ur head out of a window at 130 and think that that is going thru the engine bay…
just a thought
do you guys think i will be best off putting one back (cut off a rust free car) and my chassis number transfered across
all laquared and ready
suspension (one side) ready waiting for part for other (screw cap thingyfor top off shock holder)
hello!
