My initiation the VW world
(In Topic #102491)
So i p/x'd my Skyline for this - saw the pics the guy sent me and knew i wanted it…
So today i set forth with the task of getting it up to my secret weekend garage and having a proper look over it and giving her a basic service, plugs, leads, dizzy cap and rotor arm, oil + filter, flush the rusty coloured coolant out and replace with nice new green stuff and finally a new air filter.
First off when i was inside and out of the rain i took the hood down and took a few pics as the ones i had were quite crap..
First problem - car doesn't have a jack - so i found a suitable substitute…
Next had a good look around underneath with my fingers crossed hoping not to find any horrors…
All looks good so far, no signs of rusting down the sills and quite a few new parts visible - sump, driver side lower wishbone type thing, discs and pads and full exhaust - this has been poorly fitted by someone and front pipe to rear section is loose and held to gether with a bent bracket and has fallen of a broken rubber hanger causing a knocking vibration against the ARB…
Will be a nice easy fix though
Had a look at the new coilovers and they are as i suspected - wound up to the max - which explains why it bounces around so much - will need to wind them down a bit in the near future.
Just as soon as i can find the key for the centre caps of the wheels! The lad i bought it from is trying to chase up the previous owner to see if it can be found but i dont hold out much hope so if anyone has a key that fits this then let me know, they are borbets…
So i carry on with my servicing until i at last come to airfilter when i notice that the carb is flopping around with the airbox!!! See my other thread in big block carb engines section - that is where my day ended!
Perhaps Kwik Fit did the exhaust?!
Yeah, looks like a kwik fit job to me!
To remove the cap bolts get a decent pair of long nose pliers, had the same issue on some wheelt i had!
Best bet is remove thm, throw them in the bin and put a nice stainless cap head bolt in there.
Liking the cabby - are you in Portlethen by any chance? I noticed the Roemex Chemicals stuff all over the shop. If you are at Roemex, I used to work next door at Bluewater up to the start of the year. You may have spotted my black Sportline with red roof passing quite a lot last summer.
Good luck with gettin they centre caps aff!!
Cheers,
Chris
Mk1 Golf floor mats - for tin top and cabriolet - Zero7796 17298Five
Or gat a pin punch and tap them round
At least they have a nice starter hole bang in the middle
