My hit of Viagra - Intro and Plans.
(In Topic #82261)
I'm new on here and thought I'd intro and show you what I'm tinkering with over here in Australia.
I've rebuilt a 76'LS and putting some performance parts in it which I intend to use at the race track.
Car will be running a 2L ABF, konis all around, 11" Wilwood brakes, 24mm rear sway bar, all strut braces and Blue typeR recaros.
I will eventually cage the suker if everything works to plan.
Right now I'm up to the wiring bit and it's taking a while as this is my first time.
After that, I'll need a full exhaust system and I'll be done and start trying to get the car to drive easy.
I'm leaving for Japan this friday and will return in 2weeks to take on the wiring. Was going to send it off but some friends have told me I should have a crack with some of their help.
Look forward to picking many of your brains.
MKI ABF - Under construction.
What injection system are you using? I can't see the metering head etc… lurking in there, so I guess you've ditched the k-jet setup?
Rich
