mk1 restoration, the plan.
(In Topic #105915)
- finish sanding and clean up rust and treat wiv krust.
- use repair panels for rear arches, not sure weather to widen the car or cut up for what i need, (any idea's where best match).
- fill dents and repair other rusty areas along the sills and rear valence.
- weld in new drain cap which has rusted out in passenger footwell.
- drop rear axel (a stud sheared when i lowered it to remove fuel tank) and remove rear suspension, clean up inner arch.
- stone chip the underneath, arches and 5 or 6 inches up.
- go about fabrecating a rollcage out of scaffy tubes (welded).
- fit new fuel tank, filler neck.
- install a gti axel (for discs), and fit new rear suspension, any ideas?
- now time to make a start on the door's, bonet and tailgate.
well thats about as far as my vision is at the moment but eventualy,
- 16v engine, on webers (less wirring plus better noise).
- mate with best ratio gear box, any idea's?
- brake and fuel lines in baided pipes on the inside.
- 16v servo and master cylinder.
any idea's where to start shoppin. i.e new and brakers
\/\/ The beast to be…!!! (loads of pics) \/\/
http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&t=95838&highlight=
SSC ELECTRICAL
SSC ELECTRICAL
are you making a track only car? or a road car for track use? you can get fiberglass panel easily to save on weight.
hello!
What do you mean by fitting a GTI Axle for discs? Front or rear? The Golf doesn't use an axle at the front, and at the rear, discs are not the best upgrade path - concentrate on the front brakes.
If you're thinking of racing/track days, then I'd be going for new parts, after all trackday use wears parts out much quicker so what's the point of fitting part-worn stuff? Also it will be of unknown reliability, at least with new stuff you can kinda be reassured it will work. Especially things like brakes, suspension, which are wearing items anyway.
Best ratio gearbox - again depends on application and engine power.
SSC ELECTRICAL
SSC ELECTRICAL
SSC ELECTRICAL
SSC ELECTRICAL
SSC ELECTRICAL
SSC ELECTRICAL
ShaunyC said
maybe it could be sandblased but am in the mood for rear discs.
You'd still need to sandblast the axle….the rear disc conversion bolts onto the Mk1 axle, you transfer the relevant parts from the Mk2 axle to the Mk1 one.
SSC ELECTRICAL
SSC ELECTRICAL
