mk1 golf tfsi turbo the beast for 2011 and beyond!!!!!!!!!!!
(In Topic #130674)
a new year a new project, i have ditched my megasquirt abf for a 20t fsi engine. bought a low mileage bwa ( 200hp ) engine. just started stripping the engine and taking everything off i dont need and research what i need to make it work...so watch this space i will be uploading pics next week of the engine and the build through out the coming year. i have bought some bits from the usa i am just waiting for them to arrive....cant wait to start.
cant wait to see this!
Will be watching this also :twisted:
will be a nice project can't wait to see the build.
you nutter, i thought it was almost finished aswell!!!
george...how are you...went straight back to the drawing board...looool....how are you...saw some pics car is beautiful mate
nice project mate cant wait to c this
foxy
foxy
LOL NUTS, But sounds like its gonna be awsome, when do you expect to be finished?
im good, car is getting there slowly
a quick update on my project. I have stripped the block and i have to get it of to be cleaned...i have bought arp rod bolts...so the will be going on with some new shells, does not really need it as its only done 17000 miles or so...but want to do things properly... ecu, loom, pedal, canbus box, and fuel pump all here also. changing the water pump and will be putting back together in the next couple of weeks. i am excited i have taken pics of the block and turbo etc etc i will be uploading them soon, i have been concentrating of meeting targets i set myself so i apologise for no pics at the mo but i really have to crack on cause this is new to me.
Running the high pressure , direct injection? fuel system?
hell yea...not going to cut any corners with this build
Hi to all the mk1 owners I have been away from this site not very good at posting things up because of work and other things that seem to keep me so busy but the project has been a full on Its taken me a while to get all my bits due to fact I bought nothing from the uk..all from the usa or canada and even the tuning software comes from overseas courtesy of unitronic chipped. I have pics of the engine build so far. gonna figure out how to post them up. But I have fully stripped the blocked had it cleaned. all new parts from vw for the rebuild.
Integrated engineering rods ( all balanced )
race bearings
modified cams
apr hpfp fuel pump
arp head and main bolts
and various other bits I found while on my build journey. I will be documenting as i go along just in case anyone wants to build a tfsi in their car.
Next on the list a hydrulic clutch conversion for the mk1 and get the car off to the body shop. I will try and update you and add some pics like I mentioned.
race bearings
modified cams
apr hpfp fuel pump
pics will be be good as im also putting a audi s3 tfsi bhz engine in my mk1.
wicked...its alot easier with that engine, due to the fact the internals are stronger...and you dont really need to go crazy with the tuning soft ware
Watching this
I'm starting my mk1 project this year and still trying to make my mind up on which engine to go for.
At the minute I have a clean painted shell - just need to make my mind up on which way it's going then get cracked on with it.
Any info you can share on what's required, or share your research to date on putting this in the mk1 would be appreciated.
Thanks on advance.
Thanks on advance.
Pics pics pics please
to Raps3… here is a list of parts you need through Qpeng.com is for sale | HugeDomains
Tfsi engine ( golf, seat or audi )
Qty Description VW Part #
1 Engine control unit Various
1 Engine wiring harness 06F 972 619 [ ] (Not AJ or AS)
1 Alternator harness Various - with engine
1 Battery positive wiring IK0 971 228L
1 Engine Electrics Box 1K0 937 124K
1 Cover for Electrics Box 1K0 937 132F
1 Mounting for Electrics Box 1K0 907 361B
1 Cable Holder for Electrics Box 1K0 971 848E
1 Type 458 Relay (Normally found in engine electrics box) 1K0 906 381
1 Type 100 Relay (Normally found in engine electrics box) 7M0 951 253 A
1 Type 433 Relay (Normally found in interior fusebox) 3D0 951 253 A
1 Type 167 Relay (Normally found in engine electrics box) 191 906 383 C
5 5 Amp fuse
7 10 Amp fuse
2 15 Amp fuse
1 20 Amp fuse
1 Accelerator Pedal 1K2721503M (Black) 1K2721503L (Silver GTi)
1 Pedal Floor Bracket 1K1 721 187C
1 Pedal Bolt Hole Plug 1K1 721 989
1 Brake Pedal switch 1K2 945 511
1 CAN Gateway Unit 1K0 907 530.
5 5 Amp fuse
7 10 Amp fuse
2 15 Amp fuse
1 20 Amp fuse
just a quick pick of the block after i removed the head
