MK1 golf... any1 help with tuning ideas / engine swap please
(In Topic #120672)
Your options are pretty massive,
You have a big block engine car so you could quite easily drop a gti engine with a manual box (im guessin you want a manual otherwise performance wouldn't be the first thing on your mind lol) This shouldn't be too expensive or hard as generally speaking (as long as you have all the right bits) its a straight swap.
First off though, give the 1.5 lump a good service (oil, filters, plugs, leads/dizzy/rotor etc, do timing and double check fuel mixture) All mk1 golf engines respond well to this and you will soon see a difference in acceleration and top end speed. Next step is to get your car breathing right/better - generally a new weber carb is the way to go. Next is a free flow air filter an exhaust. Your next step will be to port and polish the head, at which point you may as well have swapped the engine for less money/time etc etc
Either way, just enjoy the car - and treat it with some respect!! :-)
