mk1 20vt, slow but getting there
(In Topic #97608)
Member 125 - 2005
here it it bought last jan, project not goin as quick as i hoped but getting there slowly………
Member 125 - 2005
learning as i go, reached a bit of a stop at mo, need a few more bits save a bit , buy a bit….
looking good what ems you going to be running the standard oem?
loving the shiny bits :wink:
Member 125 - 2005
i have an emerald ecu and qpeng wiring loom. benscab i know you have good results with megasquirt, do you have any experiance with this set up. i'm afraid that part may be more than i can do and will be asking for some help.
Looking good there Jim,the car looks nice and solid,is the shell in good order?
keep on keeping on
Member 125 - 2005
yep shell is solid, front panel has been chopped a bit, car used to run a g60 with nos , but all is good
Nice one mate.What engine code lump is it by the way?I want to do one of these later in the year once i`v moved but not sure which donor engine would be the best?mk1jim said
keep on keeping on
Member 125 - 2005
engine code is BAM with ko4 turbo
thats the big boy one lol!! that from an S3?
Member 125 - 2005
supposed to have uprated internals aswell, can't wait to get it up and running.
i think i have a mk1 20vt emerald map here
which inturn would have all the setting you need whats with the qpeng loom?? emerald should come with a blank loom which you solder your plugs to :dontknow:
Member 125 - 2005
not sure about the loom then??, did you know derbyshire is a lovely place to visit, at this time of year, ben :wink: :wink:
yeah jamie said the same thing i ended up driving for 6 hours
least derby is only 3 hours down the road
well with the loom id use the standard 20vt harness and strip it leaving just the bits you need then pigtail it onto an emerald loom
not overly clued up on emerald tbh sell the ecu buy a megasquirt and ill come up and get it running in a day
Member 125 - 2005
that's probably what's been done to the loom, how much would it cost with megasquirt and you to get it running right.?
less than buying a new emerald ecu
i have base maps for megasquirt the only thing you wouldnt be able to do is run cop (coil on plug)
i was having this converation earlier with jamie its cheaper and easier to fit megasquirt due to the fact if you want emerald mapping how much is it going to cost? ?300 minimum id guess
where as megasquirt is pretty easy to map on a user basis if you read the papers ans you would learn alot more about how it works :wink:
Member 125 - 2005
i already have the emerald ecu, but am really tempted with the megasquirt, anybody any idea of the pro's and cons for each ecu?
dont get me wrong emerald is one of the best out there and tbh if id had the money thats the route i would have gone if mapped correctly can be awesome but its the cost of mapping
megasquirt is cheap and cheerful and can be mapped by yourself oncw you understand what is what
so far i think theres about 8 people using megasquirt on 20vs 3 on this forum alone
nick82 is up and running
jamiegolf is up and running
ive been up and running for 2 years with no problems
theres loads of people using emerald out there you may find someone that can map it for beer tokens ask around on the forums the guy that builds the megasquirt may be able to map emerald :wink:
Member 125 - 2005
yep will ask around
