Mk1 1.8 20v turbo?
(In Topic #99304)
Mk1 1.8 20v turbo?
i am really want to do this conversion and make the car a minta!
But need some info on the conversion
i.e
what breaks to use
what running gear
info on the gear linkages
etc etc
if any1 has got any info they could give me wud b much apriciated
Thanks guys
jus need sum info like
any1?
cheer
Have you read the post in Mods section link here
http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&t=33950
Starting point for you
Cheers………………..
what gear box do i use and stuff stil a bit iffy on tht side of the project!
DubJon said
You have a choice:
keep 020 transmission from Mk1 Golf
use 02A transmission from 20vT, you'll need different mounts (quite costly to buy), convert hydraulic clutch to cable, and convert cable change to rod change. Or you can adapt the car to use hydraulic clutch and/or cable change if you want to - lots of work involved though.
Mullet52 said
Dont do it mate cos 'Bens_cab' will start crying like a bitch and throwing a gay tiff cos it will be faster than his cabby :cry:
Bit inappropriate to say to a new member who's signed up for advice?
they jus the standard ones iniist?
is there much 2 adapt
with the drive shats and stuff then? i aint really sure what i am guna be gettin myself init so jus what 2 know b4 i spend a 1p really
Cheeeers
02A is the standard gearbox in many later VWs, for example Mk3 Golf 16V, Corrado, Mk4 Golf (20vT and probably others), G60 etc
Basically if you buy a 20vT engine and gearbox, its 95% likely going to be an 02A box on it.
do i use the driveshafts from the 20v?
and any idea what breaks i use? vr6 mab?
theres big brake conversions you can buy which would do the trick 16v master cylinder and servo are a must as a minimum :wink:
