Mars Red 1983 Mk1 Golf GTI
(In Topic #150004)
My new project (I may have bitten off more than I can chew!)
As you can see from the pictures there are lots of issues to address. Most of them seem straight forward but I am puzzled by a few issues. The first one I want to look at is what I think could be a fuel problem:
- When the engine warms up (after a bit of steady driving) it stutters as if there isn't enough fuel getting through. The longer you drive the car the worse it gets until I have to pull over, stop and turn the engine off .
Also, is it better to do a restoration from the outside in or from the inside out?!
Hopefully after a bit of graft (and no doubt every spare penny I have!) I can get it up to the standard of some of the other great cars in this owner's club!
Thanks for the interest in my project, I hope to post whenever I improve something worth seeing or just generally chew the fat with any fellow enthusiasts.
Lee Hartness
I would do underneath, engine bay first as this is where major attention will be needed if its bad.
And I also wouldn't worry about the engine yet if your doing a small resto or taking the engine out at least as they never run the same when you put it back in
Looks like a good base car mate, congrats
Lee Hartness
Lee Hartness
On the resto front a lot will depend if you want, or need to do a rolling resto but I would suggest you go from the inside out.
Common rot points can be rear beam mounts, esp. on offside around fuel pump. Inner rear arch and filler neck area. Just have a good dig around underneath and see what you can find.
With a bit of luck nothing major and it's just needing some cosmetic work.
I've spent a few hours de-rusting everything (thankfully only surface rust!) Hammerite will be applied liberally once I get time, followed by re-fitting the back end (replacing rubber fuel lines also as they look old)
Anyone reckon I should flush the fuel lines (if so how?!) and change the fuel filter just in case the rust has been pushed through to the engine side? Is there any way to check the fuel pump/accumulator are rust free?
Typical, only went to the garage to inspect the underneath and clean my interior! 11 hours of graft later…
Lee Hartness
