Dirty Diesel GX Project
(In Topic #141760)
here`s a couple of pics to get started, looks a little shabby and this is the good side
needs new rear hatch as this one is rotten
and the drivers side need a front wing and front door here
fugly spot lights drilled through the front panel
on the brightside the main body is good and straight small bit of rust in the sills and inner rear arch other than that it appears good, hopefully won`t find any more nasties when i remove the arches tomorrow. interior is all there and pretty clean.clock is showing 193k ! should be fun seeing if i can get it running.
Twitter Manager
Also, where is that in the pics? It looks familiar.
Good luck anyway dude, may the force be with you
those pics are from the po`s house in graignemanagh co kilkenny, lovely place.
right then i spent the day stripping out the interior and cleaning the seats and the inside of the car, found a little hole under the rear seat nothing major mind so i`m happy enough so far. the front end of the sills need work inside and outside, i knew this from when i went to view it, looks like the damage was done by jacking it up and the bottom lip on the sills has folded up on itself, bit of rust there too so i`ve been looking for repair sections to get this sorted. pulled off the arch trims too and found fillers behind, don`t look too bad though so easy enough to sort out.
i need the section in the pic below, anyone know where these can be bought ? or are they included in cq`s complete sill panels ?
Diesel Possessed
A97JCE
Feeby
A97JCE
Feeby
Diesel Possessed
A97JCE
Feeby
A97JCE
Feeby
