20v Turbo Conversion-Mk1 Golf GTI Cabriolet........
(In Topic #138067)
I have aquired a qpeng ecu & wiring loom to plug & play & a MK4 Golf as a Donor Car….. I am after a comprehensive list of all the things needed to put the 20v Turbo in the MK1…….Many thanks for any feedback Given…I will get some pics up along the way…
How much of the Mk4 will i be able to use … Does the Gearbox go in the mk1 & What about Hydraulic cluth conversion..
List as Follows..
1.8 20v T Engine
Q-peng loom & ECU for Mk1
100mm Drive shafts
02j Engine Mount.????.
The pedal box will need to be replaced for one with a hydro clutch (for example - corrado)
If you didn't want to use the hydro clutch then you can get a cable to hydro converter that were available on Seats.
The engine will fit and the engine mounts are available i think from the caddy forum or eBay
you can use the cabby driveshafts as they are 100mm i believe
i think that's about it.
i hope this helps and i'm sure someone with a more extensive knowledge will be along to correct or add
get some pics up though and good luck with the conversion
thanks
Rich
1.8T CABBY
1.8T CABBY
