1982 Rebuild,1.8t 20v My First MK1!
(In Topic #150791)
My father owns a body shop which spray classics and customs as well as some normal stuff, and has kindly lent me some space in the corner!
I bought this car with just a back end in it about 3 months ago and have been gradually beavering away trying to get it solid, collecting bits and bobs along the way.
Ill try to gradually get pics etc. up of how far i have got over the next few days :-)
The day I picked the car up back in October
Finally back in the workshop after collection
Last edit: by JackWealdCoachworks
the hole left by taking out the wheel well to allow for triangulation of the rear axle
The chassis and inner arches was rotten both sides too as well as the inner arches
I fabricated new mounts for the rear axle
Looking forward to more updates. Keep us posted.
Welcome BTW.
peterg60 said
looking good loads of mk1 20v going on atm . keep up the good work and let us know if you need help
I think it's getting easier to do on a budget these days mate as there are so many that have been done and there are countless threads out there to help.
The rear panel is spot welded in
G60 Rears turned up this week, along with some more goodies
Fishnets need a retrim!
Gearbox and spare block
Does anyone know of any good re trimmers, and roughly what their charging?
is there a spacer/platform between the two springs?
Do you mean between the upper and lower spring jon? If so no the springs are tapered out in a way they fit flush at each end. Any particular reason why you ask though??
JackWealdCoachworks said
Cheers smudger, they took long enough!
I think it's because mine sits very low now with the coilies it's on at the moment but I have some extensions to fit to make it higher. I think there could be some spacers missing????
Yes between the two springs.
Its because smudgers have had the lower helper springs removed, and I want to put them back to raise the car up, now it has a heavier engine and bigger wheels. but it doesn't have the spacers/platforms if it ever had them,
I managed to get on the g60 stubs this week
And set about strengthening the back axle
