1979 Vw Rabbit Mk1
(In Topic #141636)
1979 Vw Rabbit Mk1
Left Front
Right Front
Right Rear
Left Rear
Specification's:
Number of Cylinders: 4
Bore x Stroke: 3.01" x 3.15" / 76.5mm x 80mm
Displacement: 89.7 cu. inches / 1471cc. (1.5L)
Compression Ratio: 23.5 to 1
Valve Arrangement: Overhead cam, spur belt-driven
Horsepower: 48 @ 5000 rpm
Maximum torque: 56.5 ft.lbs @ 3000rpm
Fuel requirement: No. 2 diesel fuel
Ignition: Compression Ignition
Design: Cylinder block in line, cast ironCylinder head, aluminum alloy
Cooling System: Water-cooled, Electric radiator fan, thermostatically-controlled aluminum radiator, cross-flow design, closed and pressurized.
Fuel System: Spur belt-driven distributor-injection pump, diesel injectors, "swirl chambers" and glow plugs.
DRIVE TRAIN:
5-speed, transverse, front-mounted, fully synchronized transaxle
1st gear: 3:45 to 1
2nd gear: 1.94 to 1
3rd gear: 1.29 to 1
4th gear: 0.97 to 1
5th gear: 0.76 to 1
Reverse: 3:17 to 1
FINAL DRIVE: Front wheel drive, double-jointed drive axles with constant-velocity (CV) joints.
Clutch: Single disc, dry
CHASSIS & SUSPENSION:
Frame: Unitized body/chassis, bolt-on front fenders, two-door and four-door hatchback models.
Front Suspension: Independent coil/shock absorber struts, negative steering roll radius
Rear Suspension: Independent stabilizer axle with coil/shock absorber struts
Service Brake: Power-assisted, hydraulic, dual-diagonal circuit, disc front; drums rear; Brake-pressure regulator, rear* - Only on models w/automatic transmissions.
Parking Brake: Mechanical, operated on rear drums
Rim Size: 4½ j x 13, steel rim
Tire Size: Rabbit - 155 x 13 "C" and "L" - 155 SR13 Steel belted
Steering: Rack and pinion, double-pivot steering column; 3.9 turns, lock-to-lock
ELECTRICAL SYSTEM:
Rated Voltage: 12 Volt, 55 Amp alternator (1.5) Diesel
Battery: 12 Volt, 63 Amp/hour (1.5) Diesel
DIMENSIONS:
Wheelbase: 94.4 inches (2400mm)
Length: 155.3 inches
Width: 63.4 Inches
Height (Unloaded): 55.5 inches
Track, front/rear:Front: 54.7" (1390mm) Rear: 53.5" (1358mm)
Ground Clearance: (Loaded) 4.9 inches (125mm)
Hatchback opening: Height: 51 3/4" Width: 29 1/2" Diagnal: 48 1/32"
Turning Circle: 31.2 feet (9.5m) curb to curb
CAPACITIES:
Fuel Tank: 10.6 US Gallons (40 litres)
Engine Oil: 3.7 US quarts (3.5 litres)
Coolant: 1.3 US Gallons (4.7 litres)
Luggage Space: Seat up: 15.0 cubic feet Seat down: 22.6 cubic feet
PERFORMANCE:
Top Speed: 87 mph (diesel)
0-50 mph time: 8.3 sec. (Basic Rabbit model)
Fuel Consumption: Highway: 38 mpg City: 25 mpg
Steel Wheels:
Size: 5j x 13, ET45 offset - Tires: 175 / 70 R13
Weight: 16 lbs.
Finish: Silver steel
thats really smart, cant wait to see what its like clean
whats the deal with the two fuel caps and the tow bar on the bumper?
Extra Auxiliary Tank
And It's A Extra Auxiliary Tank
Restoration
After
brucieboy
Problem's
Fuel/ Water Separator Disconnected
Bad Water Pump
Removed both and replacing them tomorrow with better one's
Paint
After
Mightve found my "Alternator Not Getting Charged"
Looked closely and found this:
Wasnt plugged in, Guessing this is the Excitor Wire ive been told about
Need help on finding out where this goes?
Diesel Possessed
A97JCE
Feeby
A97JCE
Feeby
