1.8 Carb engine rebuild - pointers needed!
(In Topic #108638)
Anyway, long story short, it was knackered and got replaced with a 1.5 JB code engine which was original fit for the GX.
This is a good engine, but as the GX is used more for weekend and occasional daily use and really i want more power, and the tired 1.8 at the back of my garage is crying out to be looked at,
I know the head has warped due to it overheating all the time, and when i stripped it i noticed piston no.4 had a scratch,
Basically what i need to is where do i go from here?
I want to do a full rebuild on it, and ideally i want to do as much of the work myself, could the scratch be removed from the block casing, will i need any special tools, if so what? and where is a good spot to by engine parts, any information will be great as this is my first engine rebuild.
(Incidentally i will be stripping the head completely so may look into gas flowing it while i'm there, any pointers on this will be good too), sorry for the essay!
Thanks, Tom :wink:
1991 Diamond silver 1800 16v Corrado 'Betty'
Gone, but not forgotten;
1985 Lemon yellow Polo coupe S
1983 Gambia red Golf C
1983 Diamond silver Golf GX
1981 Mars red Golf GTI
Normally what I'd do is use a typical ?100 secondhand engine as a starting point, remove the head and check the bores for no damage and around the castings, flanges, waterways etc for damage. If all okay, then skim the head, lap the valves in and use new valve stem seals and its not too far off good as new. The bottom ends normally last really well, 250-300k miles.
So given the ?100 cost of a different secondhand engine vs the cost of possibly reboring + new pistons, it might be more economical to go down that route.
Like i sadi in the first post paul, it was a good strong engine, the head was warped was all which meant it pressurised itself and chucked its coolant back out, never leaked oil etc. I would like to re use, would the next step be strip it fully and check scratch and components?
If it was only a cooked head why are you going to the bother of stripping the bottom end down, it is due to the scratch? If you run your finger nail through it does it catch?
So liquid metal i want, any idea how much it costs? Cheers for the advice so far by the way.
Then when we get it back we'll paint it and put it back together. just make sure when you strip it down you mark up everything where it came off e.g no.1 cylinder and paint an arrow on in the same direction on every part. when you put it back together put everything back in exactly the same place.
the engine builders will be able to tell you if the cylinder wall needs any work if it does i'd let them do it if it's your first rebuild.
hope that helps dude.
