wheel guru needed... pt2...
(In Topic #218312)
Log into Facebook
they will fit straight on my clipper but they are wider that standard - will the poke out to much or rub on the bodykit!? its standard suspension at the moment.
i struggle with offsets, et, widths, tyre sizes - jesus - its a minefield!
id like to test fit them but thats out of the question due to me being unable to drive at the mo!!!
thanks again.
sam
They'll be perfect.
I'm perplexed by the sizing rears 7x5 rears 8x0? Unless he means 7.5 inches wide and 8.0 inches wide?
Are you running standard wheels at the moment?
Try this
Alloy Wheel and Tyre Fitment Calculator. Offset, Tyre Stretch and Speedo Error | Will They Fit
Then do a bit of measuring on the car.
Ian
fronts 6.5 (185/45/15 tyres)
rears 8.5 (195/45/15)
with chrome radinox dishes
Will the et be the same if they have fitted deeper lips on the rears?
Guess the rears are tad too wide?
chrisL said
No, the ET will reduce once you fit a 2" wider dish.
been learning all about this lately! im going to fit them but recon i'll order some narrower lips and reduce the width an inch or so
Current rides:
