Rear axle
(In Topic #201079)
Went have a look as didn't look to bad and when got there it wasn't BUT and there's always one but the back axle looked like it was to one side and was just wondering what peoples thoughts were on this????
As you look from the back the drivers side ( right as you look from behind ) looked like it sat just inside the arch like it should but the other side ( left as look from back / passenger side ) was a good inch or 2 inside the arch… Like it had been banged across ( hit curb etc ) but its not long just passed an M.O.T and hasn't been on the road for last few years so if any body could help with any info that might help thanks…
Sorry for dragging it out Dibz
what wheels were on it? if aftermarket one may be different offset, or it may have a spacer missing
The rear beam is a big old bit of metal and holds both wheels, it could be the mounting points have rusted away (weak point if not looked after) and that's why the rear beam is on an angle.
Rear arches been replaced badly?
If it doubt I would walk away.
