Trouble finding 175/75/13s
(In Topic #183548)
Hi all,
I seem to be struggling to find this size tyre for my golf? One chap told me that 75 is now 80 and I would need to fit 175/80/13s but they are also a mare to find?
Anyone on here able to help?
I am running standard steel wheels on my clipper cabby and do not really want to change the wheel, as I am keeping her standard (as possible).
Life Member
My standard alloy wheel tyres are 175 70 13R.
Are you sure that you need 75 or 80???
Hi Dano,
I am just going off the existing tyres that are fitted to the car. Maybe 70/13s will be ok?
Life Member
Should be.
What model are you fitting them to???
They are steel wheels with the exterior plastic trim which fits in as a ring around the most outer of the wheel itself.
I may have found some part worns local, so hopefully this'll sort them! 5mm tread, £60 for all 4 fitted.
I am going to refurb them as they're a bit tired looking.
Moved to correct section for you.
Life Member
Dano said
Should be.
I meant model of vehicle. Year, spec level etc
Cheers Smudger / Bert,
Dano - Std Clipper cabby 1.8 E plate. As standard as they get other than the feu orange air thingy.
