Strut risers height?
(In Topic #214923)
I'm looking to fit some to my Mk1 Scirocco and worried it might hit the underside of my bonnet as there is less room underneath there than a Mk1 golf.
Ones like this unless any one knows of other suppliers?
http://www.coltechclassics.com/for-sale/mk1-golf-jetta-caddy-strut-extensions
Just been out to measure and 60mm will mean I need 2 holes in my bonnet, I've got about 30mm till I hit my bonnet.
Back to the drawing board, shame because I've read good things about the strut risers.
I've already fitted this kit., which is meant to be 30mm drop but I've still got 60mm between the wheel arch and tyre!
http://www.ebay.co.uk/itm/Eibach-Lowering-Springs-Bilstein-Gas-Shocks-Bumpstop-Kit-Golf-Mk1-/231605051979
They take you lower than you'd ever want to go, and are so comfy.
1983 MK1 Golf four door 1.8T 20V BAM remapped, MK2 dash and loom, TMI interior. daily.
2014 VW California 5.1 with full Sportline kit, weekend home.
I have had experience on a few of my cars with rabbit, cat, bird, and rabbit strikes. So much so that I have added Deer Whistles to the fronts of all my cars….. didn't mention the deers that jumped out of the way….
Hit a Pheasant and a Seagull once, it bounced through the headlight bucket and is wasn't fun cleaning out.
This was on a stock height 76 Toyota SR5 Liftback…
Haven't hit any critters since installing them
Pete M said
No these, the extra low option.
http://www.bc-racing.co.uk/applications/volkswagen-coilovers/vw-golf-mk1-74-83/br-series-coilover-type-ra-24818.html
Is that price per shock as I couldn't see any info.
Sorry, no bud, that's a full set but I sourced mine through stanced UK which were about 790 quid.
When you fit the upper spacer sleeve on the rear coilovers (which you'll take from your existing setup) you'll need 2 x m10x1.25 nuts to secure these down.
The last rear moto shock I purchased was £1300!
Pete M said
Cheers for the info.
Blimey!
These are cheap as chips then! Well worth money.
