steering column / Momo wheel fitting
(In Topic #170391)
the adaptor should keep the wheel spaced enough to not short out, if not you have the wrong boss
This has been a very helpful thread since it comes up in Google…(hence me bumping the very old post!)rubjonny said
you need a late mk2 or mk3 pressure spring, 1h0 419 667, 69p+VAT
One more relavant question though: which spline adapter is required? There are two listed in ETKA with two different overall lengths and part numbers:
191419514 ("adapter sleeve; 45MM")
191419514A ("adapter sleeve; 26MM")
My column is currently small spline with a 4-button wheel - will the spring be in place already or will I need to add one?
Stone
"Klaus": 1987 Clipper Cabrio, LA7Y, 1.8 Weber (auto)
1995 Corrado VR6, LK4Z: RIP
2003 Golf R32, LB5R
2003 Golf R32, LB5R
With the wheel off it's obvious that the spring must be behind the black plastic spacer piece (hidden by the stalks) - but the distance from the top of the splines to the top of the black spacer is pretty much exactly 26mm.
So the shorter version must have been made to allow you to swap from small to large spline without taking anything apart - just wind it on with the steering wheel nut, on top of all the stuff that's already there. Praise be to VW for occasionally making things easier for us
Stone
2003 Golf R32, LB5R
2003 Golf R32, LB5R
which seems to say it's OK, so I've ordered the short adapter from Heritage and will give it a shot
2003 Golf R32, LB5R
2003 Golf R32, LB5R
Seems to have worked fine though, wheel's on and looking lovely Horn and indicator cancelling work fine but I'll have to wait for a test drive until it's running again…
2003 Golf R32, LB5R
2003 Golf R32, LB5R
