Starter motor bronze bush
(In Topic #191860)
Stuck in gearbox
Im in the process of swapping over my starter motor to one I know to be in good condition as there is some play in the shaft of my current one, it has come out of the gearbox fine but the bronze bush that sits on the end of the shaft has stayed in its locator. I've tried penetrating oil, a slightly oversized torx bit, a screwdriver and a heat gun but I can't get the thing to budge, can't get my new starter in until the old one has come out.
is this a common problem? Any tips on getting it out if so? Don't want to use too much force or a drill really as if the bell housing gets damaged I'm looking at a far worse problem!
I should add it's the gearbox from mk2 8v GTI.
Any help appreciated!
you could try threading the bolt and getting a slide hammer on the end if you have one instead, that would save pushing on the casing
You need a piece of 10mm bar about 6" long. Fill the bush with ordinary thick grease all the way to the top, insert the 10mm bar into the bush and then whack it hard with a deadblow hammer.. the bush just hydraulics out..
Also found this while searching around
VinceWaldon.com - Stuff I Think is Cool
Will give it a crack tomorrow and let you know how i get on
