Spacers
(In Topic #202636)
Hi, i need to get some wheel spacers for the front of my car, as a set of wheels wont fit as i have 280 brakes on. I need 5mm -10mm. Anyone know some decent spacers that are hub centric 4x100?
Rob
Rob
Wanna Hug?
for that size you probably wont find any that fit over the hub lip, non-centric are fine as long as the wheel can still centre on the hub
Sorry to hijack but i also need some 5 mm spacers as my tyres now sit very close to the coilovers on the front. I was wondering if i would still be able to get away with the standard will bolts as its only 5mm or if i need to get longer ones ???
My friend recommended h&r spacers and i think 10mm? I heard the spacers that are not hubcentric are a pain in the butt. Also would i need longer bolts? I guess i would.
Rob
Rob
Wanna Hug?
measure the depth of your hub lip, that'll give you an idea of the thickness of the spacers you need. the problem is since the input and output bores are the same they have to be pretty thick so there is enough meat for the hub lip to fit inside and still leave enough metal for the outer bore to attach.
I've used non-centrics plenty of times they can be fiddly but its no big deal, main thing is you can centre the wheel on the hub once your spacers are fitted, plus they can sit flush to the hub if they're hub centrics
Yes you will need longer bolts.
I would recommend Hub centric.
You can buy them from www.venommotorsport.com
1983 1.5gl cabriolet in yellow, its the nuts!
