Servo / master cylinder spacers
(In Topic #217804)
Sorry guys, you are probably all getting sick of my braking related queries by now so hopefully this is the last one.
I've read a few posts about peoples brakes slowly binding until they lock on and require pressure being released via a bleed nipple on the caliper
I think I'm right in thinking this is due to the servo rod being too long for the master cylinder?
If this does happen, is it possible to cure this with a spacer between the 2 components
I've seen a few 1.5mm spacers on ebay and wondered if anyone has had any luck with them rather than fitting a different master cylinder
Current rides:
There is a o-ring between the booster and the MC to make sure it doesn't vacuum leak for a reason.
When ever you replace a MC you should always do a free play adjustment.
I thing what you are describing is more indicative of a internal brake line malfunction. Where the Brake line(rubber) has deteriorated, and the internals are acting like choke points.
Briano1234
I might not have described it very well.
I mean like this
http://www.ebay.co.uk/itm/192554977459
I mean like this
Current rides:
