ride too hard
(In Topic #186239)
has anyone else had this problem also when turning from lock to lock they make some horrible boinging noises really wished they had worked because is so easy to getg perfect ride hight
Im going to get KW V1 when I can afford them.
Buying cheap stuff is not always the cheapest option in the long run
All depends on whether the car is for show or blow and how much you value your spine and of course the ££
mark1gls said
Why would you want to keep adjusting the ride height? Don't you just set it at the height you want? Get springs and shocks the right drop (don't buy cheap springs and shocks or you will have the same problem) or buy some better/more expensive coil overs that's the only way to get rid of the hard ride.
Yeah, once set you leave it…. but for me I want to be able to set them just right as Ive got staggered wheels.
Looked in to air ride but very expensive (2-3K fitted) and you hear horror stories about air leaks etc.
