Rear Shock absorber bushes
(In Topic #212976)
How tight do you do the bushes up
I have fitted new Bilstein shocks and Eibach spring to my tin top gti. How tight do you do the nut that screws onto the top of the rear top bush, i have done it up as far as it will go but this seems to really compress the top bush.
The torque specs on the Bentley lists the 2 nuts separately. The inner or nut towards the shock is 20Nm.
The upper nut is 31.5Nm.
Now with that being said, I hope that you took the time to "Mummify" the lower bolt, why you ask?
Because I have fought that blasted bolt for years on my first Golf (which was off the showroom floor) and on each of my Cabriolets…. After Cutting and Torching them off I found the answer in going back was to cover the Bolt Head to Thread with "Teflon Tape" and coating it with never-seize, so in the future I could have a easy go of replacing the bolt.
Frozen bolt in the middle of the mount bushing.
Mummify that bolt.
Same bolt about 5 years later…. all bright and shiney and ready to be re-mummified.
Mummify that bolt.
Thanks Briano,
