rear disc conversion question
(In Topic #194255)
any advice would be great!
Sure my rear discs and calipers are from mk2 16v golf, 90 spec. Cables are scirroco 16v , if you use mk2 golf 16v cables they are about an inch and a half too long. You can overcome this I believe by cutting the ends of the channels under the car to get them to fit, or adapting the cables ( I tried this on cables on a previous conversion but was never happy with it).
Sure scirroco 16v cables are still available on the flea bay.
Can't comment on mk3 golf parts sorry.
pb
pbenny0 said
Hi,
pb
ill give that a whirl then!! cheers
my original thought was that jellybelly but as it was 4 stud thats why i was thinking possible mk2
I've had 2 over the last 15 years and all come with rear discs fitted from factory. Most people don't fit mk2 calipers as they are know for the head brake seizing the design on mk3 and mk4 are better.
The Scirocco cables (available still from GSF by the way) fit the early calipers but eh later ones will need the cables from a Mk2… can't remember if its the long or the short but I'll double check
mk2 cables are no use they're either way too long or slightly shorter than the scirocco ones (been thru all of this on my MK1 cabrio with mk3 rear discs!!)
could be it looks worse than it is, main thing if you work the handbrake lever it should move free and the piston in the caliper should gradually pump out (use proper windback tool to get it back in, NOT a G clamp!) if the lever is sticky or siezed then I would just bin it.
note the spring will be quite strong, so it'll take effort but it should mnove smooth and spring back under its own power strongly
rubjonny said
if you have late/mk3 calipers fitted the right way up (you can fit them upside down to convert to early fitment, just need to take off and hang right way up when bleeding) you may have to trim the tubes
under the car down about 10mm or so as the scirocco 16v cables end up a bit too tight. Basically when you look trim them back to the weld that secures them to the floorpan, you'll see what I mean.
Would it be m2 16v scirocco cables?
if the old mk1 beam mounted restrictor is still working you can keep it, otherwise people use the mk1 cab/rocco ones fitted to the master cylinder. again you'll struggle to find 16v ones but the std drum ones will be fine.
on my cab i made a laser cut metal bracket to allow the mk2 golf beam mounted valve to fit as i had one in stock and the mk1 items were extortionate prices when I was looking
As johnny has mentioned the Cabriolet ones fit but they have a diffent level of proportioning (if thats even a word!) off the top of my head.
As the Scirocco originally had 256mm on the front I suppose it'll depend on what front brakes your running as well
