Moving shifter back underneath.
(In Topic #215831)
My shifter is inside the car with a hole cut in the bulkhead for the 2 cables at the moment and I'd like to put it back in it's OE position underneath as I want to fit a centre consul.
I've purchased a 5 speed from a later model so it has the good ends on it (can't remember what model it's from but I did the research on here and got the one everybody recommends) but when I was under the car the other day for something else I noticed the lack of room in the area due to the large diameter exhaust filling some of the space.(BAM fitted) I think the pipe could be as big as 3 inches.
Is it possible to fit the shifter back under or am I stuck with it inside the car?
I can jack it up for some pictures if needed.
1983 MK1 Golf four door 1.8T 20V BAM remapped, MK2 dash and loom, TMI interior. daily.
2014 VW California 5.1 with full Sportline kit, weekend home.
Hi fitted the set up from a mk4 Gti fitted under the car , my exhaust is a stainless magnex system, not sure if it’s 2 1/2 or 3 inch, but I just wrapped the cables to protect from heat
