mk1 cabrio clutch cable
(In Topic #171800)
Events Manager
Clean the bulkhead and the plate comes with a sticky back and stick it on 5 minute job and saves a heafty repair bill if the cable pulls through.
First one I found
http://www.ebay.co.uk/itm/MK1-Golf-GTi-Cabriolet-Bulkhead-Clutch-Repair-Panel-/151203213524?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item233469f0d4
This one is listed for your car but might be worth checking with them.
http://www.ebay.co.uk/itm/VW-GOLF-MK1-CABRIOLET-1-6-1-8-CARBURETTOR-ENGINE-CLUTCH-CABLE-154721335-C520-/221254770850?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item3383cfe0a2
A hydraulic clutch uses fluid to operate the clutch so there is no cable, it works like your brakes do.
Hope you get it sorted mate :-)
You already have a strenghing plate so don't need that.
When fitting the new cable its a pain getting the rubber grommit in the hole on the bulk head put a little grease or simular on the rubber grommit and push it in the hole then push the thicker part of the cable into the bush, you will see what I mean when you come to do.
Glad you managed to find one.
