Inner CV to Drive Flange Bolts
(In Topic #185108)
Does anyone have any good tips for getting tight/knackered ones out?
I'm guessing I'm going to have to heat them with oxy-acetelene but I'm not sure I'll get enough heat in.
It's on the nearside/short driveshaft (not that it makes any difference!).
If they do round off, what do you have to do? Cut the driveshaft and take the gearbox out?
1983 White cabriolet GTi
If you still had the splined fittings, I was going to suggest making sure you had a good fitting bit that was properly driven home, then you should be OK with quite a lot of force, however if they are Allen bolts it's going to be a bit more tricky. Sometimes if the fitting is lose you can get away with using the next size up in a TORX fitting and hammering it into the end of the bolt to get a tight fit - however it's a one chance only affair that doesn't always work (but has in the past for me) I don't necessarily recommend trying it unless you've run out of other options.
Mike.
Good luck..
As you can get to the edges of the bolts, you might be able to grind a flat surface onto two opposing sides and then get a good quality (so no flex) tight fitting spanner onto the bolt. Once you've cracked the thread they will undo fine, and replacement bolts often come with the CV boot kits.
Website Manager
Is it a nut in the centre or do you need to strip the box to remove it?
Simon
Website Manager
You will have to undo the hub nut (very tight), undo and release the wishbone balljoint, pull the hub out so that you have enough room to pull the drive shaft out of the hub and then you will be able to pull it off the gearbox.
Then use some mole grips to turn the shaft of the bolt to remove it.
Another piece of poor mechanics fixed, happy days!
Thanks for the advice guys.
Simon
