i think im going a bit mad... wheel spacer issues
(In Topic #178661)
mIsChIeF mAnAgEd.... kind of
bugs-gti said
You forgot to put the spacer on the drivers side lol
I wish that were the case… But alas no. Nil pois
I assume they're 15's? They look like bbs rx2 i think
olethalb said
Have you checked the offsets of the wheels?
The offset is 45 and I assumed that all 4 wheels should share the same offset :/
olethalb said
Stupid question no doubt but spacers are both 25mm?
Yeh, I checked the spacers before fitting and both were the same :/
Is seems like a long way to be out, i've seen as much as 10-15mm shift on my 4 golfs but you can jiggle the body mounts to re centralise on them…
olethalb said
From tje pic there seems to be a whole lot more spacer on the passenger side although it could be the angle of the pic i guess
I think a trip to the garage tomorrow night is in order, I will report back with my findings!! Your right about there seeming to be a whole lot more spacer on the passenger side I was sure I checked them
'83 1.3 Golf Driver GT - Project thread
Instagram - matt.semp
ok.... update. been back to the garage tonight to get some more accurate measurements and its no where near as bad as the first pictures seemed to make it. the difference is just 7.5mm............ that end bit of the ruler is 30mm
Last edit: by al roper
83 Candy White Campaign http://vwgolfmk1.org.uk/forum/index.php?page=topicview&id=projects%2Fyour-mk1-golfs_2%2Fmk1-golf-restoration_2 89 Caddy pick up http://vwgolfmk1.org.uk/forum/index.php?page=topicview&id=projects%2Fyour-other-cars-and_2%2Fcaddy-barn-find Mk1 Scirocco project completed
Your wheels are RS772 and the 3.5 cabrio had RS772. Both usually confused with RX2. Both run et45 and should be fine with 25mm rear and 20mm front spacers.
I've got the 16" RS772 on my cabrio and run 37mm spacers with out issue.
Last edit: by jayc
