help needed from the experts5x100 hubs 310mm disc'a
(In Topic #186190)
Also I have found some 310mm disc breaks, the first problem I have that the the calipers I have do not fit onto the mounting points, Im guessing I will have to make a bracket to solve this.
Secondly the fixing screw that holds the discs to the hub is not usable as the hub has no threaded hole for this screw, will this be a problem, I am debating having a hold put in and threaded.
If anyone can tell me what disc and calipers i have that would be great.
Also if there are any brackets I can buy to fir my calipers and discs.
Thanks Tom
the MK2/3 4 stud bearing carrier ball joint pops into a hole into the bottom of a bearing carrier then a bolt goes thru the carrier to hold it. 5 stud bearing carrier ball joint goes in slightly angled and secured with a nut on top of the ball joint
brakes look to be mk3 96 on and mk4 golf 288/312 style
rubjonny said
mk1 are 4x100 as standard, if you check the steering arm on bearing carrier this will tell you if they're mk1 or mk2/3. straight out = mk1, angle down then mk2/3.
wow that's very informative, thanks very much.
So we are saying that i have myself some mk2 hubs possibly, and mk3 or 4 brakes.
Am I right.
the hubs must be custom or machined down mk3 5 stud items to fit in mk1 bearings, 5 stud outer cv spline is different to 4 stud so thats the way to tell what hubs they are
theres a good guide on the vaux setups somewhere on here
