Front bleed nipple
(In Topic #183939)
Front calliper bleed nipple
If you've got the VWII calipers then the bleed nipple is shown on this one on the top right.
It is a different size spanner to the drums on the rear (at least it is on my cabby)
Hope that helps.
Ian
I think the shaft is supposed to be edged to work as the 'nut'
Before you go any further I'd suggest going to buy some new ones. Then use some mole grips or similar to try and get it undone. Otherwise go and see your friendly local garage
As above the nipple should look like this attachment.
http://www.ebay.co.uk/itm/MK1-GOLF-Bleed-nipple-M10x1-/390753376026?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item5afab7571a
Decent pair of mole grips should free it up and then replace.
Dan
if so then id just get replacement caliper, you can find em all over if they're VWII mk2 and mk3 use em, as do even newer VAG models but watch out for very late ones may have banjo fittings which wont work with your brake pipes. as i say the nipple may be m7 or m10, the m10 ones are better if you can go for it more meat to get your spanner on
