Confused about vw heritage g60 braided lines for mk1
(In Topic #218014)
Hi guys,
Bought this G60 fronts braided lines set from VW Heritage; just need the front ones for my new g60 setup.
https://www.vwheritage.com/wc69805174p-goodridge-stainless-steel-braided-brake-hose-set-g60-front-and-stock-rear-vw-spare
I'm now really confused how they fit. Looking at the braided lines, they have female connectors…but my front calipers also have female connections… So am I missing a part to screw into the caliper and then screw the braided line onto?!
Also no idea what the short braided lines with the "ball type" ends are; and also what the big bolts in the bag are for…really confused! Help much appreciated!!
The ball type and big bolts are for when rear discs are fitted, they go onto the caliper. I think the front ones are wrong, although it may be possible to screw in an adaptor I don't see that as the best way to go..
Weird…my rear disc calipers definitely do not take that kind of ball fitting. But I only need the fronts anyway.
I'll get in touch with VW heritage and ask.
You got a link maybe to front ones you might think are correct? Thanks
So I spoke to VW Heritage who said my G60 calipers are missing a little metal bracket with a hardline adapter built into it (See first picture below).
As you can see from my calipers (the black ones), I don't have this bracket.
Anyone else come up against this before? They recommended I go to HEL to get custom brake lines made…seems expensive and I can't imagine we've all had to go get custom brake lines done!
Help much appreciated please…it's been too long sorting these bloody brakes!
In the photos I will hopefully put up, shows the end of a g60 hose that came in a g60 caliper I bought. It shows a thread on the end, I don't know if this little bit actually unscrews. Also shows the 2 ends from one of the long ones from a 6 piece kit I bought, forget where..
The bottom photo looks exactly like what I would need; a female fitting to screw onto the hard line and a male fitting to go into the caliper.
Suppose if I just knew the right threads for the mk1 hard line and the G60 caliper I could google for the right hose.
Anyone know this?
Anyone know this?
