Brake lines to compensator
(In Topic #185153)
Nearing the completion of my rebuild but have a question regarding the brake lines.
I have a brand new set of pre-cut brake lines and have just run them from the master cylinder and under the car. Both of the rear lines fall about a foot short from the compensator.
As standard is it meant to be two direct lines from the master cylinder to the compensator or did they have a join in??
After compensator is it just a direct line to each rear cylinder hose?
Many thanks
Part numbers are 113611191 for the Valve [18] and 171611789 for the connecting piece [17]
Mike.
1983 White cabriolet GTi
