Anti roll bar
(In Topic #206070)
Hi all
I'm sure this has been asked many times and I've tried to do a search but can't seem to find the right info
I have a GTI and want to upgrade the ant roll bars and was wondering what people's recommendations are?
Eibach?
H&R?
Any others?
Anybody know where the best place to get them is?
Taj
Eibach?
H&R?
Any others?
Taj
Mk1 1983 Helios Blue GTI Engineering
I have had Eibach fitted for about 20 yrs, very happy with them.
Anyone else have any reccomendations?
And who stocks these parts?
Are you still running on standard suspension?
Dropped on coilovers
Meaning you have it dropped on coil overs I don't think you will get any benefit in fitting uprated anti roll bars as I expect there is very little body roll, standard anti roll bars will be fine for road use unless you are building a track day car I would use the money on some thing else.
If you do want to buy some I've heard good things about the Eibach ones.
Thanks for the advice fella.
I haven't dropped the car stupidly low because I can't stand to hear the tyres rub so there is a little roll sometimes.
Everyone seems to go for the eibach arbs so I just wanted to get some feedback from anyone who's used the other versions that are availabile
Do all Gti's have a rear anti roll bar as standard???
As far as I am aware, all tintop gti,s have front/rear antiroll bars from the factory.
Yes, they would of been fitted with a front and rear anti roll bar.
The standard rear sway bar is way too thin to be of much use nowadays. For a noticeable improvement go for one at least 22mm thick. A cheap alternative to the Eibach or Neuspeed is to find a front swaybar off a modern car that will fit inside the rear beam. Take all the mounts from the donor car as well and weld them to the rear beam for the new swaybar.
I've used front swaybars off a Mazda Capella and Mitsubishi Sigma but that was over 20 years ago so you'll need to find your own donor.
Paul
Paul
- 1978 MK1 GL 2 door with 2.0 16v ABF, twin 40's, Recaros, lots of suspension mods. I'll get it back on the road one day.
- 1991 MK2 GTI 4 door. Was my daily doing over 1000 ks a week until it hit a truck. RIP. Got another one now and loving it!
- 1991 MK2 GTI 4 door for parts.
- 1998 Seat Cupra + another used as a donor for the MK1
- 1999 Passat Wagon. Needs street cred but at least it's a manual.
