4 speed to 5
(In Topic #188328)
Hey all
In the middle of doing an Abf conversion and needed to get all the bits sorted for changing it to a 5 speed. It was a 1.3 before, does that mean I have to change anything else for example the steering rack ? Or would my other one bw fine?
Cheers un advance
Cheers un advance
what gearbox are you fitting?
Pretty sure it's an o2a box as I'm shortly gonna be doing an Abf conversion
Then your steering rack will be fine, assuming you,ll be using the cable change,
That's the plan. Which gearbox would mean a different rack then?
Oh and the arb mounts turned up bud. Cheers for that
Glad they have arrived ok, if fitting the 02o 5 speed with the rod linkage you would need the corresponding rack as it has a little bracket on it you would need to use.
